Am avzut live anul trecut ceasul lui Lucian, cel cu 994.1....e superb :inlove:iEdi scrie:In primul rand : Lemania 8812 are la baza Longines 994 !
In al doilea rand acesta este unul din cele mai elegante, frumoase si misterioase calibre automatice create vreodata. Un mecanism pur si simplu superb, care la ora actuala mai este folosit numai de Breguet.
Longines 99x
Re: Longines 99x
Acum ceva vreme iEdi imi raspundea la afirmatia mea ca 994 se trage din lemania:
N. Paulescu
N. Paulescu
Re: Longines 99x
Edi spunea ca Lemania 8812 are la baza Longines 99X.(se vede asta in postul tau)
La momentul respectiv Lemania "muncea" cu Omega si Tissot.
Longines nu avea legatura cu viitorul Swatch atunci.
Este ultimul mecanism produs independent de catre Longines.
Lemania cumparat linia si ironie dar din fericire prin inglobarea Lemania (Nouvelle Lemania) de catre Swatch in 1999 Longines a
avut din nou acces la propria capodopera.
Un material interesant despre Lemania-Heuer (ownership)-Nouvelle Lemania-Swatch gasiti aici.
http://www.timeclubromania.ro/ceasuri-j ... 5&start=15
Re: Longines 99x
Aici gasiti date despre Lemania-heuer....
http://www.calibre11.com/heuer-lemania-part-one/
http://www.calibre11.com/heuer-lemania-part-two/
Re: Longines 99x
Dragilor, inca din primul meu mesaj din acest topic rezulta clar succesiunea Longines-Lemania-Longines etc.
"Lemania purchased the design and presumably the tooling for the Longines 990 and began producing it as a Lemania Calibre 8810. In 1991 its design was refined in some respects and released as the 8815. The 8815 was expanded into a host of other movements including a skeletonized version (8881), one with a perpetual calendar (8840) and one with a quarter repeater (8860). The Lemania 8815 and its variants are currently used in a variety of watches from Breguet and a few other mostly high-grade manufacturers (a rare, more affordable watch with this movement was produced by RGM for a TimeZone limited edition watch in 1999).
Since Lemania's acquisition by the Swatch Group in 1999, Longines has re-released watches with this movement, re-labeled as a Longines 990. Whether the Lemania 8810 continued to be produced after that or Ebel purchased a new old stock movement for their Ebel Calibre 060 is unclear to me. At any rate, the Ebel Calibre 060 found in this limited edition Ebel Lichine automatic is clearly marked on the barrel bridge as a Lemania 8810 (in addition to the Ebel calibre designation)."
Va prezint o imagine cu ceasul Ebel 1911 Senior din colectia mea (in articol se vorbeste despre modelul Ebel Lichine; am vazut unul odata, 'live', fara secundar si fara data, deci corespondent lui Longines 993)
Re: Longines 99x
...nu a contestat nimeni ca ai pus link-ul care explica legatura.
Am dorit doar sa intaresc ce se spune in link-ul respectiv cu informatii mai clare care arata si legatura interesanta
cu Heuer si altii.
Daca am gresit sa ma ierti si daca doresti sa dezvolti doar tu acest subiect eu ma retrag fara probleme....
Am postat link-ul (intr-un mod neortodox care a suparat/imi cer scuze) deoarece colegul Zaytsuca a adus in discutie
legatura respectiva.
Doar din acest motiv si nimic mai mult.
Re: Longines 99x
... si Girard-Perregaux Gyromatic (GP 214-157) corespondent lui Longines 994.
Re: Longines 99x
Haide Lucian, (iar) esti pus pe glume?Lucian Marcu scrie:![]()
Ai subliniat bine - si ai facut bine asta.
Zilele / saptamanile urmatoare o sa postez si eu poze cu cele 6 Longines 99x pe care le am - aproape la fel de frumoase ca ale tale!
Dar ca sa le arat frumusetea ar trebui sa le fac niste poze mai bunicele ...
Re: Longines 99x
Ce fain e decorata varianta GP,parca e alt mecanism.
Re: Longines 99x
... si ce proaste sunt fotografiile ... si cata nedreptate ii fac acestui GP!Lucian Marcu scrie:Ce fain e decorata varianta GP,parca e alt mecanism.
Multumesc Lucian!
La acest GP incarcarea rotorului se simte mult diferit (in bine) fata de oricare dintre Longines-urile pe care le am, inclusiv Ebel 090 / Lemania 8810.
Ultima oară modificat 10 Oct 2022, 10:42 de către Achraf, modificat 1 dată în total.
Re: Longines 99x
Un model mai putin intalnit din aceasta familie, cal. 997.2, cu secundar central si fara data.
Datele furnizate de Dr. Ranfft:
http://www.ranfft.de/cgi-bin/bidfun-db. ... ines_997_2
Longines 997.2
Features
manual wind
sweep second
Data
11.5''', Dm= 25.6mm
H= 2.65mm
17 jewels
f = 28800 A/h
power reserve 44h
Longines 997.2
Features
manual wind
sweep second
Data
11.5''', Dm= 25.6mm
H= 2.65mm
17 jewels
f = 28800 A/h
power reserve 44h
Re: Longines 99x
The missing link:
Longines automatic cal. 890 - "greu de ucis"!
In momentul de fata, din seria aceasta imi lipsesc:
889 (hour angle disc) si 992 (automatice)
996 si 998 (mecanice)
Pe ultimele 3 nu le-am vazut niciodata. In afara de Ranfft nimeni nu le nominalizeaza, nici macar Boley.
Or exista?
Pina cand se va dovedi ca exista, consider ca din familia aceasta imi lipseste doar 989 ...
Ii multumesc unui bun amic de pe acest forum pentru placuta surpriza pe care mi-a facut-o cu acest ceas!
Or exista?
Re: Longines 99x
Salut.Si eu am un LONGINES din aceasta serie si anume:994 swiss 4184.Cam care ar fi valoarea lui reala?(ma gandesc ca il vand)
Re: Longines 99x
Cautati pe www. In acest forum NU SE FAC EVALUARI!
Re: Longines 99x
NU doresc evaluari aici pe site!Doresc sa vorbesc cu un cunoscator al aceste serii de ceasuri IN PRIVAT! “EVALUARE“ IN PRIVAT!
Re: Longines 99x
Poate doriti o "evaluare " la domiciliu? Atunci dati un anunt in mica publicitate locala.pelorus scrie:Doresc sa vorbesc cu un cunoscator al aceste serii de ceasuri IN PRIVAT! “EVALUARE“ IN PRIVAT!
