Hamilton Intra-Matic. Clasic,fara power-matic,ieftin si frumos:
https://www.hamiltonwatch.com/en-int/h3 ... matic.html
Undone Basecamp Automatic
https://www.undone.com/en/basecamp
What’s special about it is:
it’s distinctly domed to achieve a real, retro look; and
it’s made of a polycarbonate thermoplastic called LEXAN™.
In non-nerd terms – that’s pretty much shatterproof plastic with 250 times the impact strength of glass!
Se pare insa ca acest LEXAN este mai slab decat vechiul si banalul Plexiglas ... (desi cei de la Undone zic altceva).
https://www.acplasticsinc.com/informati ... vs-acrylic
Una peste alta, pretul de ~300$ nu-i chiar asa de rau ...
JLC Master Grande Tradition Répétition Minute Perpétuelle
Minute repeater and perpetual calendar. These are the two complications of this new limited edition, reflecting Jaeger-LeCoultre's mastery of both mechanical and aesthetic precision. Decorated in elegance with blue guilloché enamel and understated white gold, the Master Grande Tradition Répétition Minute Perpétuelle watch revives the tradition constantly revisited by the Rare Métiers®. A rare degree of finishes adorn both the face of this timepiece and its case back, where the components of its automatic movement in action are exposed. A rare series of just 30 editions.
TECHNICAL DETAILS
Jaeger-LeCoultre Calibre : 950
Case : White Gold, Water-resistance : 5 bar, Diameter : 43mm, Thickness : 13.7mm
Functions : Year, Perpetual calendar, Date, Hour - Minute, Day, Month, Moon phases, Minute Repeater, Seconds, Red security zone
Recto Hands Dauphines
Movement : Automatic, self-winding, Components : 585, Vibrations per hour : 28800, Jewels : 79, Barrel : 2, Height : 8.48 mm
Dial : Blue, Appliqued hour-markers
Strap/bracelet Leather
TECHNICAL DETAILS
Casio G-Shock GD5000-9JR solid 18-karat gold
Casio G-Shock will release a limited edition GD5000-9JR made with a solid 18-karat gold case, bezel, bracelet and screws. Featuring G-SHOCK’s iconic square case and shock resistant structure, the new model will be the brand’s most luxurious timepiece and its most expensive watch to date. With thirty-five pieces available globally, only two will be sold in the United States. It is now available for pre-order (until May 31) with shipment set for this December. For details, click here. Price: $70,000.
https://world.g-shock.com/asia-mea/en/p ... -710251413
Retro ! 1973 din 1973. Oare o dori cineva sa aiba 1 din 1973 ?
E frumos Tissot-ul asta.
Mi-e teama, insa, ca la 43mm o sa fie cam mare.
- gherghin nicolae
- Moderator
- Localitate: petrosani
rubin scrie:
Ala din 1973 avea alt mecanism .
Evident !
Au scos ultimele bucati de Tissot centenar la comanda online. Acum cateva saptamani erau in 15 magazine din Bucuresti. Azi numai in 9 magazine.
Sa nu va grabiti, ca vi le tin. Au zis ca numara userii activi pe forum si pastreaza cate unul pentru fiecare user.
Personal, nu-mi place nici macar designul, daramite brand-ul...pentru aceasta aniversare preferam macar un Peren Nera implicat, macar e mai “autohton”...dar e parere strict personala.
Oricum, e prea tarziu, Tissot e singura varianta existenta pentru doritorii de “aniversare” de gen.
Ar fi fost mai elocvent daca l-ar fi botezat nu Pe-ren ci Pe-nibil.
Frumos acest Bulova,marea problema e ca daca ai mainile ocupate nu poti vedea cat e ora.
Mie imi place Peren; consider ca personalizat pentru aniversare putea fi un ceas super. Nici eu nu sunt atras de Tissotul aniversar, e un model foarte utilizar de Tissot, personalizat prin coloristica si foarte putin modificat ca design fata de modelul original. E o parere strict personala. Stima!
Da. Si eu as fi preferat sa afiseze constant ora, nu doar la apasare de buton, dar are consum foarte mare (datorita LED) - bateria tine max. 2 ani. E posibil sa-l trec pe lista de achizitii ...Tibaldi scrie:Frumos acest Bulova,marea problema e ca daca ai mainile ocupate nu poti vedea cat e ora.
https://www.ablogtowatch.com/bulova-com ... d-watches/
