Acum este 28 Mar 2024, 11:53
MesajScris: 29 Sep 2019, 21:29
Salutare si bine v-am gasit, fiind nou membru pe forum.
Am achizitionat in urma cu 6-7 luni un ceas Citizen AT8110-61E, Eco Drive Radio Controlled, plus un alt model, tot Citizen Eco Drive Radio Controlled (la care nu am la indemana codul). Cel fara cod, avand curea de piele si fiind un model care imi place mai mult, l-am purtat frecvent, merge perfect, se sincronizeaza, nu sunt probleme. Celalalt, AT8110-61E, a stat in sertar, cand deschideam si prindea lumina, se seta (cred eu) automat, probabil prinzand semnal.
Recent am vrut sa il scot de la naftalina si sa il port, problema e ca nu isi "ia" ora corecta, si nici data nu o pot modifica (rotita in pozitia 2, rotesc de ea, cadranul de la data ramane blocat).
Din ce scrie pe el, astea nu se desfac. Daca are cineva experienta cu astfel de modele si ma poate ajuta cu un sfat, as aprecia. El merge in sensul ca are bateria, iar daca modific orasul, isi ia alta ora, problema e ca nu corect (de ex Londra e cu 6-7 ore in urma). Si ar mai fi problema zilei, care pare blocata. L-am lasat la soare cateva zile, in speranta ca isi "revine", dar nu pare sa fie solutia corecta.
MesajScris: 30 Sep 2019, 01:08
Pentru data sigur nu faci bine ceea ce faci. In manual scrie asa:
1. Pull the crown out to position 1.
2. Press and hold the upper right button Ⓑ for two or more seconds. The second hand moves to the 30-second position and the chronograph minute hand moves to the 60-minute position.
3. Pull the crown out to position 2. The second hand moves to the 0 second position, and it becomes possible to adjust the time/calendar.
4. Press the upper right button Ⓑ to select the correction target.Each time you press the upper right button Ⓑ, the correction target changes as follows and the corresponding hand slightly moves.①Time (minutes/hours/24 hour time)→ ②date→ ③day of the week → ④year and month→ back to ①
5. Rotate the crown to adjust each setting.• If you spin the crown quickly, the hands for the time and date will move continuously. To slow down and stop them, slightly rotate the crown. • To move the date forward or backward by one day, slightly rotate the crown. • The year and month are indicated by the second hand. Adjust them by referring to the figure in the next page.
6. Repeat procedures 4 and 5.
7. Push the crown in to position 0 to finish the setting.The second hand starts moving from the 0 second position, and time/calendar indication will resume. • Push in the crown by referring to a reliable time source
Manualul complet e aici: https://www.citizenwatch.eu/cwe/product ... n/H804.pdf
MesajScris: 30 Sep 2019, 08:34
Hidralazina, sunt bun de cinste, merge brici! Eu le-am luat la pachet, la ocazie, ca sa ies avantajos la pret. Implicit, n-am la ele manuale samd, am cautat setari pt Radio Controlled, dar n-am gasit.
Iar asta nu pot sa zic, ca m-a pasionat, avand unul 99% identic, l-am tinut in sertar si am vrut sa il vand, dar parca nu prea :) Astea 2 radio controlate au fost setate de tipul de la care le-am luat si am inteles ca se seteaza singure, eu neavand cum sa le setez, d'asta si "sperietura" mea ca nu isi ia ora corect.
Spor!
Hidralazina scrie:
