Ernest Borel Datoptic Incastar (Felsa 692)
Ceasuri Diverse
... and here is the beast ...
Felsa 692 Bidynator (Ranfft)
Features
automatic
sweep second
date
Data
11.5''', Dm= 26mm, H= 6.6mm
17/21/25 jewels
f = 18000 A/h
power reserve 44h
Caracteristici actuale:
17 Jewels, Incabloc
power reserve 43h
precizie: + 2 sec\ zi
incastar regulator http://www.ranfft.de/cgi-bin/bidfun-db. ... &Felsa_693
(Incastar
The only large-scale produced regulator featuring a free-oscillating hairspring. The end of the spring is fixed between two rollers, adjusting actually its length (photo at the bottom). Rolex's unimaginative solution by troublesome weight screws on the balance is replaced here by a sophisticated micro mechanism - both eliminate the isochronism error due to the gap between the regulator pins.)
dimensiuni:
33.5 mm x 42.5 mm x 12.5 mm; band 18 mm
All Stainless Steel
(intre timp i-am schimbat coronita cu una care sa se potriveasca asa cum trebuie)
... ultima foto nu imi apartine ...
Alfie
Localitate: Balanesti,capital
Mesaj de Alfie »
Regulatorul este senzational.Mai poate fi intalnit la Mido
A fost o vreme cand doar Rolex si Felsa detineau patentul pentru automatic-rotor,restul produceau automatic-bumper.
Un ceas rar care trebuie restaurat.
Cu siguranta merita
