"WATCH MOVEMENT DETAILS are usually of LITTLE IMPORTANCE-- Unless you are an expert, connoisseur or collector, do not worry to much about the details of the movement inside a watch beyond whether it is a) quartz, b) certified mechanical (Chronometer), or c) non-certified mechanical. Frankly, most watches from any premium brand are sufficiently fine devices for keeping time that will give you several decades of use if properly maintained. Technical details of the mechanical "movement" (the actual mechanism inside the watch) are seldom particularly important unless the watch you are buying is over $10,000 or has some unique functions. Over 98% of mechanical watches made mainly tell the time, date, and maybe include chronograph functions. All mechanical watches with just these basic features use technology invented over 75 years ago, and nobody has really improved it since then. So do not waste time fooling yourself into believing one standard mechanical watch mechanism is perceptibly different from another--especially to the extent of paying more for one watch over another based on that attribute alone. "
Oricum, valoarea mecanismului dintr-un ceas premium nu depaseste 5-10% din valoarea ceasului,indiferent ca e mecanic sau quartz.
"Cost to Manufacture: The high quality quartz movements used in better luxury watches are slightly cheaper to make than their mechanical counterparts, though the difference is not that great. Keep in mind that cost of the movement in most luxury watches accounts for only a small portion of the final retail price -- less than 5%."
